Best ever CPU Cooler?
I gotta say my Akasa 965 is a good cooler. It will keep my E8400 at 30c idle and under 57c load at 3.6Ghz.
Even at 4.1Ghz it keeps it below 65c on full load. Best bang for buck.
I would say the AS Freezer as it was/is cheap, standard fitting and not that big and was a massive upgrade from stock and normally the first 3rd party cooler people get (me included).
TRUE is the best air cooler ive used on par with *water cooling if you can take the fan noise
*some watercooling setups will obviuosly be better or worse, but i would say a TRUE is definatly on par with a 120 RAD in terms of cooling.
