Best ever CPU Cooler?
Cheers, had heard about the v8 and the v10, looks like a decent cooler, currently using a lapped TRUE black on my q6600, keeps the temps at 68-68-62-62, prime load @3.8ghz, normally run the system at 3.6ghz, prime load temps of 60-60-55-55, cooled by 2 x 200 rpm fans.
Love the transformers-ish look :p
EDIT: Fan orientation was fixed for the final build :P
Tuniq Tower for me With my e8400 clocked at 4gig the tuniq keeps it at 60 degrees with 100% load. I'm thinking thats a pretty good temp for that clock on air
And I think it looks pretty kool to boot :)
Killari isnt that fan on the wrong way?
Quite liking my Noctua, its cooling my e8500 at ~4.3gz running prime at the moment and temps around 60 :D
Yeah just set the fsb on my mobo to 480 just trying the 9x multi and if it passes might up it to 9.5x to see what happens :D > 4.5ghz here i come!
XD Phew!
P.s. looks like a very tidy setup you got there widdyst, but those 260's must be a bugger to cool!
They werent too bad mate really I stuck a big fan on the side panel as below to cool them so temps never really got over 65-70. But I have since dropped back to just using 2 260's as I found the third to be of no benefit at my resolution in fact on occasions it was actually hindering performance and causing more lag and stutter. Now I have the 2 in sli I am well happy with performance can run crysis etc maxed out with no stutter :)
220 mm side fan :)
ps Hope the 9.5 multi works for you mate
For TRUE extreme air performance (pun intended, if poor!)
and...
Am starting to get sentimental now... although the water set-up is quieter
from my experience push was always slightly better although you could run two fans in push-pull at lower RPM (quitter) and get better performance
why not just point it up? then the big fan at the top will act a little like a pull! thats the way i have stuff arraged in my case. I had a push-pull arrangement but have taken the pull fan off as made hardly any difference
