You're trying to explain Tricep kickbacks!daven1986 said:put one knee up on a chair / bed / bench with your other foot flat on the floor then lean forward. in the arm that is not over the chair / bed / bench hold a dumb bell with your arm in an L shape with your fist facing the floor. now extend the arm. this should work your triceps nicely.
daven
(i really didnt explain it well did i?)
Nazbit said:
Chong Warrior said:You're trying to explain Tricep kickbacks!
... quite possibly THE biggest waste of time known to manplease whatever you do don't perform these in public, you will (and should!) be barracked mercilessly
In answer to the original question, weighted dips own all and are the daddyclose-grip bench are also serious mass builders, they won't be as good with dumbells though and might be a bit tricky at first but still better than the other exercises
A2Z said:weighted dips
end of
daven1986 said:why are they rubbish?
Goatboy said:the best exercises are the ones that allow you to move the most weight.
thats my exact routine for chest/shoulder/tri dayPAz said:After heavy benching, overhead pressing and dips my triceps feel like they're about to explode!
