I have recently put up a greenhouse and would like to know what kind of flooring materials I should use.
The greenhouse was put up on some grass, so the floor has been covered for the last couple of months to kill/suppress the grass. I was planning on putting some polythene sheet down with loads and loads of holes punched in it followed be about three inches of 20mm crushed gravel. Does that sound ok or are there any other alternatives I should consider? I can do the above for £45 odd quid. I'd prefer cheaper options tbh.
I plan to do all my growing in pots/grow bags, so don't need access to the earth.
Many thanks
Many thanks
