Best mayo for fries
Heinz light for me.
Certainly not the most popular choice but is just what i'm used to!
Nandos Hot Perinaise if I want something a bit different.
Know what you mean about the Dutch/German mayo though, it's definitely different to the Heinz/Hellmans mayo we get here!
Has to be Heinz, it really does. Not Hellmans. Not own brand. None of the Polish muck either.
For the record, fries and mayo = chef's kiss!
what's your fave mayo for fries?
The one I make myself.
Ingredients: 2 egg yolks, 300 ml olive oil, 1 tsp mustard (either Dijon or English, to taste, depending upon whim), garlic, salt, pepper. Note: use good mustard: the cheap mustards have dyes in them which will discolour your mayo.
Put 2 egg yolks in a metal bowl - important for incompetents like myself as it keeps the mixture cooler. Drizzle a very little oil - a drop or two - into the yolks and whisk it in. Add a little more, whisk some more. Repeat, gradually increasing the amount of oil you add at a time. Add the mustard, a good grind of pepper, a pinch of salt, and crushed or finely chopped garlic to taste (I use 3-4 segments) and whisk it all in. For a luxurious mayo add in another egg yolk at this stage. Leave in a sealed bowl in the fridge overnight to mature.
Instead of garlic you can substitute chopped dill if you are serving salmon, mint (be very careful to add only a little) or rosemary if you are serving lamb, and so on.
Anyway, what you have here is an opportunity: give your guests a choice and see what they prefer.
But it's the Belgian GP this weekend so how about making some Béarnaise sauce?
This stuff is great, it's made with just the yolks.
Heinz salad cream, splodge some into a dipping bowl and stir in a bit of scotch bonnet sauce, makes a good basic spicy dip for chips.
Alternatively, a chip buttie with a rich layer of Sandwich Spread on the bread instead of butter makes a good chomp.
