- 25 Oct 2005
I've not really tried homemade mayo before. Must give it a go. I make homemade bearnaise sauce - That is ace with chips too
Put 2 egg yolks in a metal bowl - important for incompetents like myself as it keeps the mixture cooler. Drizzle a very little oil - a drop or two - into the yolks and whisk it in. Add a little more, whisk some more. Repeat, gradually increasing the amount of oil you add at a time. Add the mustard, a good grind of pepper, a pinch of salt, and crushed or finely chopped garlic to taste (I use 3-4 segments) and whisk it all in. For a luxurious mayo add in another egg yolk at this stage. Leave in a sealed bowl in the fridge overnight to mature.
The egg yolks would need to be cooked as a "sabayon" initially
Duh! Gravy goes with faggots, marrowfat peas also acceptable.This 100%. There is only 1 dip for a deep fried cut of potato and it's red not white.
Mayo is for faggots....
Its only mayo, no need to get homophobic......This 100%. There is only 1 dip for a deep fried cut of potato and it's red not white.
Another vote for making your own, super easy with a food processor.
I thought that was only for sauces based on Hollandaise (i.e. with liquid clarified butter). Anyway, I did state that I was incompetent.
BTW wrt metal vs glass, I do find my mayo splits far less often when I use a metal bowl.
I agree Pepe.Ketchup goes with chippings, not mayo.
Very few of us are Dutch or German on OcUK fella
I found this however. This seems to be the main one. Basically home made Mayo but jazzed up.
Frietje Met: Dutch French Fries with Homemade Fries Sauce
These twice-fried French Fries are perfectly crispy on the outside and fluffy/crumbly on the inside. Paired with “frietsaus” or “Dutch Fries Sauce,” Everything is homemade! …www.toineskitchen.com
