How many passes of memtest would you normally allow to consider the RAM NOT the problem ??
Done two passes so far and been crunching for about an hour...
No point buying anything new tbh. The 975 chipset can't push memory too high, so you're only choice would be low latency kits (800Mhz Cas3) which are expensive.
Faster memory doesn't help things much, better to save for a full upgrade
