Should be able too, although if you can't it is because it is the Lite version.Ice Rich said:Just trying winamp now, its very smallusing the lite version - can I use different skins?
MarcLister said:Should be able too, although if you can't it is because it is the Lite version.
See http://winamp.com/skins/. Personally I use either MonoDark which comes with Winamp or the Spirit Black from http://www.deviantart.com/deviation/10310941/
quoted for truth tbh.james.miller said:foobar does it all and with a small footprint. Id love to know why people recommend winamp over foobar.
I wouldn't quite go that far!! Have you ever tried using Realplayer??Kainz said:Tbh anything is better then WMP.
DDave said:Probably because you don't need to spend hours messing around with plugins etc on winamp to make it look ok and do it what you want to.
If you have plenty of spare time and patience to mess around with foobar then thats the better option.
and it does virtually everything you want it to out of the box.
