Hi Guys,
I'm looking to take up road cycling.
What is the best road bike for £300ish.
My google skills have picked up the Triban 3.
Does anyone else have any other contenders or is this the one to go for?
Thanks
http://www.ribblecycles.co.uk/bbg/r...training-audax-bikes?sub=conf_BBRW&type=RIBMO
That's the cheapest road bike IMO, it's also pretty much all you need, what with 95% of the performance coming from the guy sat on it!
Other than that, have a look at 2nd hand as suggested by Stinger53
triban 3 for sure! had mine for a little over a month and love it! really feels like a quality bike!
That says "from £595" so it doesn't fit into my price range unfortunately.
I would be willing to go slightly higher for a big difference in quality but not that much higher.
All the reviews I have read have been very positive.
I just wanted to check if there was anything else out there before committing.
I'm not sure I like the idea of 2nd hand bike which I know is stupid. I just like shiny new things
Best Road Bike for £300
No such thing new, I have linked the best inexpensive roadbike.
Thread should read "I'm going to buy a Triban 3 what do you think?"
what you mean there's no such thing? triban 3 is the best bike you can get for 300 quid ?! what are you trying to say its not a road bike? im not sure i got you here.
Buy the Triban 3 then! /thread.
That Ribble is THE best entry level road bike full stop.
its double the price too? you sound a bit fanboy-ish..
i personally would go second hand.
Good grief! Fan boy??
I have owned Cannondales costing £2500.
That Ribble for the money is a great bike.
If you want the Decathalon bike buy the ******* thing and stop trolling.
Well OP has answered the question himself in the first post..
What's the point of posting on a forum if you already know the answer?
