If it helps, I've just bought the 60GB OCZ Vertex 2E after several recomendations. Depends how much space you need and for what purpose. I've got mine for Windows and games. Everything else will go on the other drive I have.
Probably several yet then Tom, the 3rd gen don't even seem to be close to the elusive £1 per Gb yet, let alone less than half that.
I went for the 64GB Crucial C300 SSD and I'm very happy with it so far.
You're a lucky git, my games would easily fill up a 500GB drive![]()
Show off!! I'm only using the SSD to run FSX (It needs all the help it can get). Everything else will be on a 1 TB WD Caviar Green.
Good luck with your quest.
