Best way to...
Mp4
Mp4
21 Apr 2006
Eastbourne
Greetings all,
I've been given two laptops
1 - Win XP
2 - Win 7
And have been asked if i can backup/clone the XP laptop to the win7 but apart from just using a usb drive to copy files etc im not sure how to proceed.
I was thinking of using a clone program but not sure what to use as i don't want to copy the OS.
Can anyone help :)
Microsoft do a migration tool - windows easy transfer. I've heard of issues with it though, so everytime I've needed to do the same I Just do it manually. Big external HDD and move things across. Is there software that needs to move as well?
If they use outlook it is possible to move the pst file properly if you do it right, if it's just normal files then just copy them over.
