Better cooling for 3870
i'm debating whether to even bother water cooling my 3870's, they're pretty good on the stock cooler with no noise.
depends on how much more heat they will generate with the modded bios and pushing past 900mhz.
that zalman you linked should work really nice on these.
well i just took off the stock fan and that stupid exhaust thing that my nan could fart more air thro then the blower... straped a high cfm 80mm to it. core @ 860 ram @ 1387... idle is 43*c just downloading 3dmark 06 now to test stable and maybe push the clocks higher....
Edit : Which programs support the 3870 for bios editing ? can you point me in the right direction please
