Better than an iPad?
as above Android is better yes you get adds in the free games but they are better than IOS if you go for the asus nexus 7 it has a tegra 3 quad core 1.5ghz cpu 16gb internal memory for £199 aprox which is better than APPLE
Is there a better tablet than the iPad?
What do you want it for?
Internet - iPad
Games - iPad
Music - iPad
Films - iPad
Photos - iPad
Battery life -iPad
Hate on Apple - Samsung galaxy tab 2 10.1
If you have any other apple products then you will find an iPad will integrate more easily. If not then the choice is really up to you
What i don't like about android is how fragmented all the apps are. Meaning, they have a massive amount of screen sizes to account for and very few apps actually work "well"
Dont buy yet, wait for the Microsoft Surface tabs to come out and have a look then if they are crap then the worst case scenario is that with another line of tabs on the market it should send other tab makers into a frenzy and see them pushing even cooler stuff out the door....... maybe lol
Better codec support with android imo
Perhaps so but if you have films on your PC then you will make sure they are in a format most things understand. If not then they are downloaded films from whatever source you use in a common format (although even i refuse to use iTunes for movies)
Your opinion, not fact in any way.
I have a nexus 7 and ipad 3, i prefer the nexus, its lighter, its better for what I use it for. The ipad is technically a better bit of kit, it just depends what you use them for.
I don't like Apple.
But your post is very biased, and incorrect, also very opinion based.
it got the tf101 and it is great also i read somewhere flash is getting put back on google play for a shhort time but not for jelly bean that qill use HTML5
also dont forget android has got flash support where as apple doesnt plus apple losing google maps and youtube support from its apps
When you say "apple is losing Google maps and YouTube". What you mean to say is "Apple is choosing to remove Google Maps and the native YouTube app because they want to break free from the tight money grabbing claws of google and make their own service to rival that of Google's and what Google has added to android but neglected on iOS.
Google maps on iOS was fast falling behind Google maps on android because Google refused to add more services to it. And the YouTube app is the same as it was 5 years ago when the original iPhone launched, it was always crap and the web based on i much better."
martini im not being biased i have used Apple products and Android products and think Android is better i own 2 items an S2 and a TF101 and they are both great also im just giving my opinion about a product
Your post doesn't come across at all as balanced.
Thinking Android is better, that's fair (Personally, I think it's a mash up, android is massively fragmented whereas IOS isn't quite so much) but you made a blanket "Android is better" That's biased on a subjective based topic.
The Nexus 7 doesn't have a 1.5GHZ Tegra 3. Off the top of my head I think it's clocked at 1.2GHZ.
Think it's I/O performance isn't that great also.
Apples ios is less buggy than android, but they do not offer all of the same features as one another. Therefore the first thing to do is check what features you want. Further, apple products usually just work with little config required. Android often needs more tinkering but also offers more customization options out of the box. Do some research, try a few out if possible and make a decision, everyone has different preferences after all
