till you hit 10k posts is the reference here I think.
The first, 2000 RPM.keates
rate of acceleration is measured metres per second per second.
if using the same car, 2nd gear and accelerating from 2krpm (200lbft) and then accelerating from 6krpm (100lbft), which will have the higher rate of acceleration? OTBE
thing is, the car with 200lb torque at 2000 rpm can be faster than a car with 100lb at 6000rpm, because you havent said that the 200lb at 2000rpm is the 'peak' output...nor do we know its redline, it could peak 200lb at 2k rpm and maintain that all the way to 9000rpm...(unlikely but possible)
You are just adding unnecessary confusion; the original question was very specific, two torque figures and two RPMs and the instantaneous acceleration in either case. Providing the gearing is optimal for each engine, the one producing the most power will be accelerating hardest at that point.
gearing it mentioned, its the same car so the gearing is the same, for the sake of arguement make it first gear
i think youre just adding unnecessary confusion, it doesnt need to be that difficult at all.
if you want to keep it dumb - can you not just accept the answer from page 1 that torque x revs = power and leave it at that?
Notice that the peak value of torque output is approximately 15 times greater than the mean torque output of the engine (the torque which the dynamometer measures).
so far, for the "bhp=acceleration" arguement, the only reason is that at higher revs its doing the torque more often (which makes no sense to me because the engine isnt an impact gun, it rotates smoothly consistently)
