Yes, deffo do that!
When you installed, did you remove all partitions of the HDD, and give it a full NTFS format? Is it a brand new HDD? Or moved from your old rig? Might be some old boot info from your previous installation? Doubt it, but you never know?
I had issues with my XP installation on my new rig, mine was throwing a BSOD though, and it wa sa prob with my ram, but i happily installed it a few times on different HDDs to see if it wasn't the HDD that was the problem (I done that before I knew it was the RAM of course, as I thought it was the HDD at first).
