Bios setting help for Corsair memory please.
12 Sep 2006
Bios 1407 setting help for Corsair memory please.
Finding myself going around in circles trying to work out what settings to use and change in my BIOS V1407. I have an ASUS P5WDH mobo and I’m using a matched pair of Corsair XMS2-6400C4 2gb.
CPU-Z is showing the following
DDR2 2048
Freq 250.2
Cas lat 5
Ras to cas delay 6
RAS 6
Cycle time 18
Bank Cycle time 1
Which does not seem right. Could some please help? Thanks.
Ok I’ve been looking around the web and found that I should have these following settings set:
1,DRAM Timing selected to manual and select
2,SDRAM CAS Latency: 4T
3,SDRAM RAS to CAS Delay 9tRCD): 4T
4,SDRAM Row Precharge (tRP): 4T
5,SDRAM Active to Precharge Delay (tRAS): 12T
6,SDRAM Write Recovery Time : 5
7, Command Rate: 2T
8,DDR2 SDRAM Voltage: 2.1
9,DDR2 SDRAM Clock: Manually set to 800mhz
If I disable the “Config dram timings by SPD” I can then set:
Dram Lat : 4
Dram Pre : 4
Dram Cas# Delay:4
Act to Precha : 12
Dram write recovery time : 5
Would that be the same as items 2 to 6 ?
I cannot find an option for the Command Rate 2T as in item 7 or an option for SDRAM Voltage as in item 8.
If I change the Dram frequency from Auto I get the following options:
DDR2-500
DDR2-666
DDR2-833
DDR2-888
DDR2-999
DDR2-1110
DDR2-1332
None of which give me the option of item 9 (800mhz)
Any help would be most appreciated.
