Which version of 3D Mark would I use?
Firestrike on default settings will be fine. It will give us an idea if your gpu is performing as it should.
will the bios make a difference considering my card is essentially a 290x from 2013, around the same time my motherboard was released?
I get 45fps average so not too far. You're also well below the review benchmarks!
My 3D mark score is 10,858 on firestrike
I've probably mis-read, but i think he was getting that at 1440p not 1080p which I thought was what you were running at? So a fairly significant difference in performance - he's slightly below the reviewed performance but not much, you're miles off.
(Apologies if I've totally misread that, it's early...)
That dirt rally one is interesting- with maximum setting, when I run the benchmark I get 45fps.
Is it throttling or anything? It usually sits at 75c+ after half an hour of gaming.
Hmm this is interesting. With my 1440p monitor I get 30fps with my Fury X, i5 4690k, windows 7. Dirt Rally everything maxxed out benchmark - with Vsync. Latest Crimson.
http://i.imgur.com/4jTCqmh.jpg
Turn Vsync off and results are much better... but also 45fps average
http://i.imgur.com/JwwjoqK.jpg
That is odd compared to my result with the lower Fury Tri-x model. The only significant differences are the cpu and OS, you have the i5 (4690k) & Win 7 while I have the i7 (4790k) & Win 10,
As a lover of Win 7 and a hater of Win 8 you should move up to Win 10 while it's a free upgrade. With a few small tweaks like how it downloads updates it's as good as Win 7 was.
I think I have figured out what might be causing my problems. When I load into a game (playing a lot of Far Cry 3 and 4 and GTA V at the mo) I get a stuttery 35fps or so. If I turn off vsync and turn it back on again it locks to 60fps. Is this a driver issue or something?
I'm using:
I'll give the beta a try cheers
Rather than rolling back drivers, you could run clockblocker in the background. It has fixed my 380 woes turning GTA V from an unplayable mess in to a solid 60FPS.
http://www.guru3d.com/files-details/clockblocker-download.html
