Hi there
Today is a great day as we see the launch of the BitFenix Fury power supplies which are built by FSP so the quality is fantastic and with the exclusive usage of Japanese capacitors throughout for improved lifespan. Also the other great feature is these Fury power supplies as standard come with Alchemy cables, anyone who knows modding will knows these cables are of superb quality and look absolutely amazing.
Here are the models:-
BitFenix Fury 550W Gold Modular Power Supply - Alchemy Cables @ £99.95 inc VAT
For a long time, the power supply is one part of the PC that users prefer to remain unseen. These dull, lifeless boxes were made to perform in the background, away from sight. Challenging the status quo, BitFenix set out to make a power supply that not only delivered on a performance level, but also utilized enough design elements to let it stand out in a system build. To that end, BitFenix announces the Fury Power Supply Series. Featuring top quality components like all Japanese capacitors, a killer design aesthetic, and top-notch efficiency, Fury is set to become the new gold standard in semi-modular power supply units.
Starting with the chassis, Fury brings a bold yet sophisticated design to the realm of power supplies. Both top and bottom are adorned with a stamped BitFenix logo, along with a custom aluminum ring accent that exudes an aggressive look no matter which direction you install it. Combined with a quality matte powder-coat finish, Fury is the first PC power supply that's designed to enhance the look of your system.
After taking the modding world by storm with the Alchemy lineup of sleeved cable extensions, BitFenix has brought its one of a kind Nanosleeve braiding to the Fury Power Supply. Each cable that comes with Fury is sleeved with Nanosleeve braiding for excellent flexibility and unsurpassed aesthetics. With Fury, modders will spare their warranties while saving hours of time sleeving their own PSU cables. Best of all, the semi-modular design allows builders to only use the cables they need, reducing cable clutter and improving airflow inside the system. For the boutique modded look with zero effort, look no further than BitFenix Fury.
All of this power is harnessed via several key components and technologies that make Fury a power supply users can rely on day in and day out. To ensure clean output and long life, Fury employs a design that utilizes all Japanese capacitors. Renowned for their quality and longevity, all Japanese capacitors puts Fury in a class above other PSU designs. A 135mm fluid dynamic bearing fan not only helps keep temperatures under control, but does so with minimal noise. Finally, Fury also comes equipped with BitShield Six-Point Protection, a series of safeguards that prevent damage to the PC caused by electrical anomalies, including under voltage, over voltage, short circuit and more. All of this is backed by a five-year warranty so users can use Fury with confidence.
Available in 550W, 650W, and 750W models, BitFenix Fury delivers a trifecta of performance, reliability and aesthetics perfect for today's high octane PC builds.
Specification:-
- Built by FSP, Designed by BitFenix
- Dimensions (WxHxD): 150mm x 86mm x 160mm
- MTBF: 100,000 hours
- Efficiency Rating: 80Plus Gold
- PF Correction: Active
- Operating Temp. 0 - 40°C
- Protection Features: Over Voltage / Under Voltage / Over Current / Short Circuit / Over Temperature / Over Power
- Safety Approvals: CB / TUV / ULOR CUL / BSMI
- 3.3v: 24A
- 5v: 24A
- 12v: 42A
- Total Power: 550W
- 1x 8-pin CPU Cable (8+4+4)
- 4x 8-pin VGA Cable (6+2)
- 3x SATA Cable (quad, dual, dual)
- 1x Molex Cable (triple)
- 1x SATA + Molex (1+1)
- 1x Floppy Adapter
- 4x Standard Screws
- Warranty: 5yr
Only £99.95 inc VAT.
ORDER NOW
BitFenix Fury 650W Gold Modular Power Supply - Alchemy Cables @ £115.99 inc VAT
Specification:-
- 3.3v: 26A
- 5v: 26A
- 12v: 50A
- Total Power: 650W
- 1x Floppy Adapter
- Warranty: 5yr
Only £115.99 inc VAT.
ORDER NOW
BitFenix Fury 750W Gold Modular Power Supply - Alchemy Cables @ £129.95 inc VAT
Specification:-
- 3.3v: 30A
- 5v: 30A
- 12v: 60A
- Total Power: 750W
- 1x Floppy Adapter
- Warranty: 5yr
Only £129.95 inc VAT.
ORDER NOW
Specification:-
- 3.3v: 24A
- 5v: 24A
- 12v: 42A
- Total Power: 550W
- 1x Floppy Adapter
- Warranty: 5yr
ORDER NOW
Specification:-
- 3.3v: 26A
- 5v: 26A
- 12v: 50A
- Total Power: 650W
- 1x Floppy Adapter
- Warranty: 5yr
ORDER NOW
Specification:-
- 3.3v: 30A
- 5v: 30A
- 12v: 60A
- Total Power: 750W
- 1x Floppy Adapter
- Warranty: 5yr
ORDER NOW
