BitFenix Prodigy Mini-ITX Cube Case
This is going to my first build in about 10 years, need to get somethign setup for GW2 and i'm also currently getting the garage converted into a cinema room and this will fit quite nicely in :p
Going to go with a Asus P8Z77-I DELUXE Intel Z77 with a i5 3570K, ATI/AMD6950 and I think I can squeeze a corsair H100 in if I take out the optical drive bay. Any suggestions for a PSU?
The 4th July seem so long away........
did apple see this product :D
very nice looks but its very borrowed shall we say :p
so is there a matx version off this or similar ?
Matx version had better have a similar volume...
I like the execution of this case, but I would never use so many hard drives, or watercool, or use a 50" graphics card with a mitx motherboard. Waste of space in the case tbh. :(
On the build above maybe a lower end complete loop like a antec/ corsair h60 etc cooler would be a better option. For a couple more quid. More space for air to escape & move.
Just got mine but can't for the life of me find a decent board for my 2500k, least not one that will fit my cooler!
120mm.......... small.............???????
remember this is a small case and is capable of taking 5 120mm fans or a mix of 230mm/140mm/120mm.
plus the case is designed to have zones to pull the heat out of different areas?
I watched a review where they said some incorrect doodoo.
I just bought this case LOL!
Im gonna put a 230 in the front 140 at the back and 2 120s on the top in mine.
Building next week will put the log up :P
Acme :P Its been so long now I cant even remember why LOL!
Thanks. Will check it out.
