BitFenix Prodigy Mini-ITX Cube Case
Having a little dilemma now over colours. The motherboard I've ordered has blue ports, but my 7970 is obviously red.
In a white case, what colour do I have my fans and cables from my PSU??? red or blue
Mine says "in warehouse queue". And now they've probably all gone home. Not happy if mine hasn't shipped since they've had enough hours since they posted at 12 they were in stock.
Mine coming being half 12 and half 1. Going to have a fun afternoon :)
Mine just came check this out
NOPE!
Just gave up and left it like this lol -_-
I got the bint in there in the end
24 pin will swing round over the top and the 8 pin through the side and the 2 other pcie on the other side with the other bunch i have not cable tied anything but when i do it will look a bit better.. took a lot of force getting that big boy in there. I may get the psu braided instead of buyin a modular one would look better n save some money i reckon.
So got my prodigy.
Have taken out the HDD bays and ODD mounting.
Mounted 2 SSDs on the side of the PSU cage. Also my Antec TruePower 650w fits fine and dandy in the cage.
Some pics taken on my phone:
I thing I'm gonna cut my PSU wires in half, they're way too long.
Or I might make some new custom length if I can find the stuff I'd need.
I've just ordered a few sets of the metal pins which are inside the plugs
I'm going to cut the cables down put new pins on the end then put the original plug back on,
Ordered enough to do my 24 pin, 8 pin, and my pci-e pins. I'm off work on Thursday and Friday, so hopefully give it a go.
My psu is fully modular so if I ever need longer wires I can just buy new wire and make them long again, I wouldn't do it if my 24 pin was hard wired in.
I've also ordered 1 sata power end plug so i can cut the rest off the cable, I'm only having one ssd so it should help keep clutter down
My mobo only arrives tomorrow tho, so I can't measure cable length just yet.
I'm just gutted that everything I have has a blue theme, then I'm stuck with an ATi gfx card with a big red stripe & fan :(
Aftermarket cooler? Or Blue themed water loop?
My "theme" is mostly the same. Blue, with a white case.
Completed my build, but my H100 seems to have crapped itself. Some sort of power issue so I'm going to RMA it.
Up until that point was a great case to work with, just need to get some fan extensions/black sata cables/psu braided extension cables to tidy the build up. Also internal USB extension if such a thing exists so the big USB 3 isnt resting on my mobo (my mobo only has USB 2.0 internal)
