[...] they need temp probes working to use the channels manually. [...]
So i thought i would drop in and join the fun...
Gotta say sorry to everyone for the delay of v1.2 but we're getting really close now and it really should have been a v2 with all the work that's gone in to it![]()
Thanks for all your hard work. The new functionality will hopefully get us closer to what I have been looking for. A low cost way to control fan speeds based on water temperature in a watercooled system.
The recon works fine with aftermarket water temp sensors and its very useful having desktop access to water temp, air in temp, air out temp, etc.
Working with fixed profiles has been good so far but the software auto and combining of channels to a sensor will really make this device shine.
Id just like to say thanks guys, after spending many an hour trying to get the Bitfenix software to work your programme has been easy and a joy to use ...keep up the good work.
Just as im not sure. I have installed the standard software (Bitfenix OEM software) Do i still need to be sure that the Fancontroller service is disabled or not started before using your software or can i leave it running?
Hmm do i see some potential work between yourself and BitFenix????
