Bitfenix Recon Users
Caporegime
12 Jul 2007
United Kingdom
Does anyone have this fan controller that can help?
The software that comes with it is diabolical.
Everytime i start my computer up it puts all the fans at 100% and slowly lowers them to my preset speeds once windows boots.
However every few minutes it ramps a couple of the fans up to 100% for no reason at all then lets them drop back down again.
I didnt want to bother with the probes as it seemed like a lot of hassle but will the fan controller only work properly if i use them?
EDIT
Think im starting to get the hang of it now, at least using their APP ive managed to set three different profiles.
The probes from what i saw are fairly important.
I have 3 fans but only using 2 probes and i cannot control the speed of fan 3. The default built into the recon is that if it cannot sense a temp then set fan on the corresponding channel to 100%
forget their app its crap go here sign up for the beta app and use that then uninstall the other recon stuff
http://forums.overclockers.co.uk/showthread.php?t=18444320
Use the probes setup the software based system and let it do its thing all my fans including cpu spend most the time turned off not with a brief blip on the cpu fan when the heatsink hits 30 degrees
That's normal for micro-processor controlled fan controllers. It's a sort of POST for the controller and the fans. My Sentry LXE does it.
Thanks guys, ive setup some profiles and i think ive got the fan controller under my full control now using the Bitfenix app. Happy so far.
A question for Corsair 600T users, does the bitfenix recon controller stick out on the front of your case?
Mine sticks out like a few extra mm than i think it should. However the other holes in the controller+screws to attach to the 5.25 bay just make it stick out even further.
EDIT
I had to snap off the 600t 5.25 drive bay adapter thing, now the holes line up and it doesnt stick out.
I was going to get this fan controller, but read a lot of people having issues with them so I decided not buy it. I'm using my Aerocool Strike X panel instead. The only thing I hate about the aerocool strike is it doesn't have profiles, other then that it's a great fan controller.
