Hello everyone,
I recently built my PC and I am using a BitFenix Shinobi case.
As soon as I saw the USB 3 plug I was baffled as there was a standard USB plug/wire coming off of it. So I just plugged in the USB 3 plug but left the other one as it wouldn't reach any of my standard USB headers.
I plugged all the other front panel connectors in, including another USB header cable. So, now I am left with a problem, only one of the USB 2 ports works on the front. Is this because I haven't plugged the USB 2 cable coming off of the USB 3 cable in? or should they both work off of the 1 header?
If need be I can unplug the USB 3 cable and plug the USB 2 in temporarily to see but I thought it might've been for backwards compatibility or something...
If anybody can shed some light on the subject then that will be appreciated. And if any more info is needed then just ask
Thanks,
Cam.
Thanks,
Cam.
