bitspower rotary failure :(
18 Oct 2002
Liverpool
not a welcoming thing to find and unsure of the damage at the moment but pretty sure at least one of my 6950's is dead, the movement the fiting had was proberly less than a couple of mm sorry for the lack of decent picture late at night and silly iphone camera
i can only assume that it's the o-ring that is inside the rotary mechanism that has failed and somehow coming out of the joint
i believe it's the dual rotary, can confirm once i get home from work though
confirmed from invoice it's the dual rotary
am also having trouble working out an RMA, hated having to buy from who i did but was only place with stock at the time
is it easy to RMA direct to bitspower? as there website seems some what out dated and not fully working i know cheeky also but wouldn't mind a couple of freebies as this failure appears to be costing me a lot of cash to replace some hardware
ahhh that would be the website problem then
unfortunately the reseller is not playing ball and i so wished it was you guys
I would have them by the balls, If they sold me a fitting unfit for use, I can guess who you bought it off btw.;)
it appeared fine before i installed and i rotated it very slightly to avoid a bracket and was working fine for at least a month no pressure on the tubing or barb, then coming upstairs saturday night i found a wee leak and a little puddle of water on my graphics card and system not running
have just tested a few bits after 36 hours in the airing cubboard and psu, both gpu's, and i believe motherboard is dead also as no lights coming on the boot display, i would imagine if board okay and cpu dead it would at least power on
and they are a 4 letter named reseller :( and ironically the first time i had used them
I had exactly the same problem with Bitspower dual rotary fittings. I had 3 leak but luckily while I was leak testing so no harm done.
Well all the ones i have are pretty much impossible to turn...
Im hoping thats a good sign.
I have at least 8 Bitspower compression fittings which have been running with no leaks for the last 14 months - I too bought them becuase I thought they were the best, so far... so good!
i hope you took pics .if this is a problem with the fitting and it's blown your gpus and other stuff then surely you can claim for it all????
small update bitspower is going to replace the barb and added this to there last email to me
(If you can have firm information with exact issue that this was cause by us, we will try our best to help you solve the problem on your hardware).
have lots of pictures also but unfortunately they just look like graphics cards, no blown caps or anything
