Bizarre - DVB-T PCI Card problem.
10 Sep 2005
Tingley, Leeds
Hi All:
Here is my problem: -
I have a PC which has been working fine with the Hauppage WinTV-HVR1300. Signal strength from my rooftop aerial is 100% and solid. Perfect reception. However since the pc is low spec it struggles to record. Plus I wanted to swap the card to my higher spec day-to-day PC. When I did this the signal was zero strength and the card failed to scan any digital channels - even with same drivers and aerial. It did however manage to grab the analogue channels perfectly. Thinkin I may have blown the card I swapped it back. Again 100% quality. Damned odd me thinks. Especially since its same aerial, same card, same drivers and the two PC's are in similar locations in my house and being fed by same downlead. (no splitters etc.)
So I buy a cheap Pinnacle DVB-T PCI. Would you beleive it!!! The same thing exactly! So now I'm beginning to think that the PC that is failing to work with both cards has too much RF interferance internally possibly? Or could it be something else. I am at a total loss. I would really like to cure this.
Anybody had any similar probs? This is doin my bloody swede in and I'd rather not build another PC.
Cheers,
Normsky.
PC specs below.
PC where signal is zero: -
Windows XP Professional Service Pack 2 (build 2600)
2.25 gigahertz AMD Athlon 64
ABIT AV8 (VIA K8T800P-8237) 1.x
2048 Megabytes Installed Memory
NVIDIA 6600 AGP
PC where signal is good and both TV cards work 100% fine: -
1.80 gigahertz AMD Sempron
Abit NF-M2 nView
512 MB
Noise internal to the PC can easily knock down (or out) a signal to a TV card.
All I can suggest is:
1) Check the earths on your cards are nice and tight and that screws used to fasten in hard drives etc are secure.
2) Ensure that data cables and power cables are routed as far away from the TV card as possible.
3) Install the TV card away from noise makers such as the Graphics Card
