Blacklight Retribution
This sucks, Just downloaded a 3.5GB game, only to have to sit around and wait for a 5GB patch?. Why not just torrent the whole damn thing, It only came out today
Ewww the graphics are POOR in game, the framerates are terrible and you get a horrible rippling effect on the ground when walking in certain areas, coupled with all this after the patch fiasco. This one may well die if they don't do something, can't believe it was in beta!
I couldn't log into my account, reset the password 5 times but still said it was wrong.
Sounds like their own website did me a favour.
I was baffled how this game has multiple settings of Dx11 tessellation, depth of field, MLAA tech and a bunch of other modern stuff, but the game still looks pretty damn poor? :confused:
I only gave it a few games but:
Do you like high ping europe servers?
"" Call of Duty with Robots?
"" Time played and payed gear over skill?
No to any of them and this game isn't for you :D
I noticed that too, wooooo check out all these settings!
Then I see what looked like a blurred untextured bus right in front of me as I play :D
Had a reply from a member..
have you turned off Dx11? i had rippling textures to , yank dx11 and its gone.
turn off light shafts, motion blur, depth of field too. these things are frame hogs and dont really add much.
your rig is significantly more powerfull than mine yet i can pull a decent frame rate all the time , DX11 isnt optimised properly and is known across the forums as a troublemaker its best to turn it off.
as for your gameplay experience , give the game a chance once its running ok its solid (if occasionally buggy) and the community is good.
Try that too LokiS
Just had a quick blast.
Runs fine on my system, didn't touch any settings.
For a freebie, I think the gfx are pretty good. Not a bad game so far but I need to see what the CTF/KOTH games are like as I just played some DM.
I did.... MAX MAX MAX :D
