blinking tap cartridges
jcr
jcr
29 May 2011
southampton
does anyone know how to identify the cartridges in taps, i have a leaker. i see on ebay there are lots of different types. why dont manufacturers use washers any more? is it a scam to force you to buy new taps every few years? :(
i know how to get them out, its measuring them im not sure about. is it the length and diameter of the knurled spleen on top of the cartridge that i have to measure or another part of the body?
Cant remember how I did it exactly, took it out. Measured. Looked on screwfix and found some. Found the specs / measurements and job done. Try it. Can always take them back. Or take one with you and check in store.
not sure you won't get turned over at screwfix they're about £4 ea on ebay once you know what you need,
if you can definitively id the tap on the internet , you can get the right part up front .... several earlier threads on this.
