Blue screen of death
28 Jan 2005
Hi all,
Just recently bought a new comp and put it all together (1st build), and havig installed windows + sp1&2 and a few other bits and bobs I've started getting the blue screen of death, it then resets and goes back to windows and brings up a serious error report with the following summary:
http://oca.microsoft.com/en/response.aspx?SGD=a1d34874-fa4b-4651-b1aa-0c0c0ad33740&SID=10
Its happened about 10 times now. It seems to happen quite randomly (for example last time it happened I was trying to dl the 1.12 patch for battlefield 2), and so far is fine when I play games on it.
When it first started doing them it hit me with about 4 in a row once I had uninstalled the nod32 trial (which didn't work properly for some reason), and the balloon pops up saying you have no av software installed - it didn't seem to like that balloon when it faded away and immediately blue screened again. I managed to get round it by clicking close button on the balloon instead then installed norton to shut it up.
Trying to remember what I installed other than nod 32 that could have done this as I don't see what it could have done, I can think of 3 things but not sure if any of them would have done it, but I the errors seemed to start some time around all of these (except option 4):
1) trial of nod32, which didn't seem to work on my comp so I uninstalled it
2) installed a toolbar onto ie (the one that includes a popup blocker). When I did it it asked if I wanted to continue running script errors on ie (could this be it? I can't remember what I clicked but I seem to remember it saying one option was a good idea and I may not have clicked that option lol. How would I fix this if so?)
3) I installed sp2
4) Could it be hardware setup related? By that I mean its my first build, so could I have not plugged in something correctly?
Could it be a sign of a faulty part?
Any help would be much appreciated, thanks
Could be a number of things always hard to pin down what it is, has the pc ran steady when you first built it? If so try a restore point for then.
Could be dodgy RAM seems to cause no end of trouble.
Just a shot in the dark I guess.
Good luck anyhow.
Another strange thing I forgot to mention is that the 'safely remove hardware' option is always in the bottom right of the screen, with the option to 'remove' my hdd. Its a Samsung SpinPoint P SP2004C 200GB SATA-II 8MB Cache - OEM (HD-017-SA), and is the first SATA one I've had, so is this a normal option with SATA drives?
Full spec if its hardware related:
£64.50 x 1 - Antec Sonata II Piano Black Quiet Case - 450W Smart Power
PSU (CA-040-AN)
£69.95 x 1 - Asus A8N-SLi SE nForce4 SLi (Socket 939) PCI-Express
Motherboard (MB-101-AS)
£179.95 x 1 - OcUK GeForce 7800GT 256MB GDDR3 TV-Out/Dual DVI
(PCI-Express) & Call of Duty 2 Bundle - Retail (GX-032-OK)
£99.95 x 1 - AMD Athlon 64 3200+ Venice 90nm (Socket 939) - Retail
(ADA3200BPBOX) (CP-118-AM)
£28.70 x 1 - NEC ND4551 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM
(CD-026-NE)
£99.95 x 1 - OcUK Value 2GB (2x1GB) PC3200 184pin DDR Memory Dual
Channel Kit (MY-006-OK)
£48.90 x 1 - Linksys WAG354G 4-Port Wireless-G Broadband Router
(NW-044-LS)
£57.95 x 1 - Samsung SpinPoint P SP2004C 200GB SATA-II 8MB Cache - OEM
(HD-017-SA)
£7.95 x 1 - SpeedLink Ares SL-8740 Headset (SP-021-SL)
The RAM as you can see is OcUK's own, do they often have problems?
Anyone else with any ideas on how to pinpoint the problem, and whether I need to return and exchange the RAM or anything else? Is it worth doing the RAM just to be sure?
One thing I've always been a little concerned about is that the external fan on the psu has as of yet never turned. I've been assured that its a dual fan so the internal one will be, but could it be a faulty PSU as well?
I'll have a go at that, but I haven't been onto any dodgy sites or anywhere which normally bring up this problem. Only thing I downloaded other than webpages, before installing a virusscanner, were the service packs and stuff from my old computer (on which I had an uptodate Norton running).
As I am only a few days into this new comp I wouldn't lose anything if I did a format full reinstall of windows - is it worth doing or is it not that sort of problem?
Sorry a bit nooby with all this!
Hmm, just looked again at you oca and the error message was an example and not the actual one!
What appears on the BSOD?
It flashes up too quickly for me to catch much of it. Only thing I have seen is that it performs a physical memory dump (sounds like me after too much to drink) before restarting.
Any way of slowing it down :P
edit: I'd try to create the situation whereby it BSODs again but so far it hasn't been any one thing which definitely does it.
You didn't need to install SP1 then SP2 by the way...
To stop automatic restart, right click My Computer, properties, Advanced, Startup and Recovery Advanced and untick automatically restart. That will allow you to view the BSOD.
Dunno if this could give any further clues, but I just re-dled the bf1.12 patch (can't seem to get an uncorrupt copy, was previously assuming it was just a faulty download), and this time when I ran it it came up with this message (usually the patch just fails):
CRC Error: The file c:\Games\EAGAMES\Battlefield 2\RendDX9.dll doesn't match the file in the setup's .cab file. The medium from which you are running the setup may be corrupted; contact your software vendor.
Would point out no BSOD with this, but suggests my directx may be corrupted. Does this seem to be the case and would this explain the problems? If so, how do I go about removing directx and reinstalling it (or is it just a case of installing it again, no removal required?). I'll be reinstalling Directx 9.0c from my gcard cd.
What Enfield ment about Sp1 & Sp2 is that Sp2 includes Sp1 as well, so there's no point in installing Sp1 THEN Sp2 :) Just go for Sp2 straightaway.
Also, it sounds like you could have a memory issue. Google for Memtest86, there is an ISO version which can be burnt to a CD using Nero etc.
Reboot with it in the drive (making sure your BIOS is set to boot from CD first) and run the program.
It will scan all your memory in the PC and tell you if there is a problem.
Well, I wouldn't call Memtest the hard method :)
Before Memtest you would have had to swop out memory sticks until it stopped BSOD'ing or not as the case may be. Now thats the hard way :p
Lol sorry that was in reply to enfield reinstalling windaz. Will do the memtest.
Just got another Bluescreen, had disabled autorestart this time tho, this is what it said:
Problem detected, windows shut down to prevent damage
File: NVTcp.sys
attempt made to write to read-only memory
crap about disabling newly installed hardware and software, inc using safe mode
Technical info:
*** STOP: 0x000000BE (0xB007A807, 0x12DF1121, 0x89548BEC, 0x0000000A)
NVTcp.sys - Address AFFF4459 base at AFFF2000 Datestamp 4253b85b
(Dunno if that last bit helps interpret the problem more, sounds far too technical to be of any help but thought I'd include it anyway)
Any further ideas?
edit: it came up with the same serious error screen when windows restarted:
http://oca.microsoft.com/en/response.aspx?SGD=e7b5d32d-d693-4d76-bd4d-09cdec0b303e&SID=10
Okay, narrows it down a bit.
When you installed the nVidia drivers, did you install the NV Firewall and ActiveArmour?
If you did then I suggest that you remove the NV drivers (from Add/Remove Programs in Control Panel), reboot the pc, then re-install the drivers but without the Firewall and ActiveArmour, oh and the NV SW IDE drivers are just as bad so dont bother with them either.
ah rocknroll, I did install them, certainly the nvidia firewall anyway, think Active Armour too. Will do as you say and report back.
ok uninstalled them (accidentally uninstalled the SM Bus Controller and Ethernet controller too! Reinstalled those off the mobo cd tho, although not the ide driver as instructed) and reinstalled the display drivers. Is there any way to check if this problem still exists, beyond just, er, waiting to see if it happens again? Or will that have deffo sorted it out?
Thanks for your help on this Deathwish, and everyone else who's been so kind as to post. As a reward, a joke I just heard which has me tickled:
Two dyslexics are in their living room.
D1: Can you smell gas?
D2: I can't even smell my own name!
:D
edit: looking on add and remove programmes - I have nvidia drivers, nvidia forceware network access manager, and nvidia wdm drivers still installed - should any of these go (what are the wdm drivers for?)
Just have to wait and see if it BSOD's again. This is why I hate nVidia chipsets, they have awful drivers that cause no end of problems </mini rant>
The wdm will be something to do with your 7800.
If it still BSOD's then there is one more thing that you could try, with the drivers.
