- 28 Sep 2012
So I bought a prebuilt custom rig from OC. The specs are:
4670K [Not overclocked]
R9 290
Aftermarket CPU cooler [Artic Cooling]
1TB Seagate HDD
16GB memory
Phantom case
The order form said the max CPU temp under stress test was 70c but since having the rig I regularly run at 70-75 just playing CSGO. Yesterday I had temperatures up to 84c still only playing CSGO without any programs in the background.
I've had the PC for around 6-8 weeks now and I've had on average 1 blue screen a week. I've had 2 different codes from the blue screens which are; 0x1000007e and 0xa0000001.
Yesterday while playing CSGO, I noticed the FPS was dropping from the standard 300 cap down to 40/50. I know this is perfectly fine FPS range for gaming, but it shouldn't be running at that frame rate for a game like CSGO.
I've spoke to OC 3 times so far, they've had me; run memtest, remove the motherboard battery and now I'm running seagate tools to check my hard drive.
They told me the temperature for the CPU is nothing to worry about but I can't help worrying that the temps are too high for the little stress I'm putting my rig under. My old rig was 4 years old and it ran CSGO with the CPU keeping under 65c.
Any ideas what I should do?
Thanks
Ryan
R9 290
1TB Seagate HDD
16GB memory
Phantom case
Thanks
Ryan
