By key fob programmers!
More details on here - http://pistonheads.com/news/default.asp?storyId=25953
How did they get the vehicle unlocked?!
To think, he spent all that on a 1M then went cheapskate on his CCTV system, it's bloody awful.
Read the text in the link.
There is a 'void' in the alarm. Almost like an area that isn't covered by it. This runs along the door from top to bottom and front to back and extends into the car by 4 inches (just enough to get your hand in and down to the OBD port) BMW won't admit it.
aye? does not look that bad? what would a better CCTV system have done? filmed trainers in better quality? their faces were covered so not much a cctv can do unless it shots lazer beams when it spots a hooded cockroach walking near a car..![]()
Maybe it's not limp mode then.How does going into limp mode stop you from stealing it? Or is it more the fact you'd then need to visit a dealership?![]()
.He should've invested in a garage!
Madness that he leaves such an expensive car out on display.
Over here the insurance on expensive cars requires you need have a button/buttons somewhere in the car which you press in a certain order within minutes of starting the ignition, otherwise the car goes into limp mode.
Surprised this technology hasn't made its way to the UK..
The ODB port should be in the glovebox![]()
Peugeot and citroens had such technology in the 90s. Whereby you had to enter a code or it wouldn't start. Basically an immobiliser which required a pin rather than a programmed key.
I guess people didn't like them very much because they didn't catch on.
Either way. By the looks of it there are bigger problems with BMW security than just with the software... Being able to smash a window and reach the diagnostics port without setting off the alarm is ridiculous!
