Are you sure it isn't your cabin filter or bacteria in the face level vents?
Stunning colour
Positive, I can smell it from the outside when inspecting the water from the spray.Are you sure it isn't your cabin filter or bacteria in the face level vents?
I haven’t topped it up since buying the car from BMW so I’m guessing it’s whatever was used for the last service.What screenwash are you using. The BMW stuff is pretty much alcohol. I guess if it evaporates you could have issues but generally mines ok when using genuine fluid and topped up every 6months or so
Would my M Performance exhaust and the M Performance steering wheel be classed as modifications for insurance purposes? They were on the car when I bought it from BMW and I think it was spec'd like that when built, or they were added shortly after it was delivered to the dealership.
I'm just thinking if someone rear ends me and the exhaust is damaged, they'd might put on a regular exhaust and the MPE is nearly £4k with the carbon tips which mine has.
No its not!!!San Marino Blue is the best BMW colour full stop. Sadly it wasnt available on the x5 otherwise I would have had it.
No its not!!!
Marina Bay Blue is!!
Guess what colour I have?
Maybe ask your insurance company?I'm just thinking if someone rear ends me and the exhaust is damaged, they'd might put on a regular exhaust and the MPE is nearly £4k with the carbon tips which mine has.
Because most of them are idiots and will just blanket say that it must be declared and charge more money.Maybe ask your insurance company?
In which case then you should probably declare it in case someone rear-ends you and it's not covered?Because most of them are idiots and will just blanket say that it must be declared and charge more money.
Phone BMW and see if the parts department recognises you have the M Performance exhaust fitted or the generic. If they say generic then you may want to declare.I'm just thinking if someone rear ends me and the exhaust is damaged, they'd might put on a regular exhaust and the MPE is nearly £4k with the carbon tips which mine has.
