Is that how the ambient lighting is in the 5 Series or has someone added that crappy light strip stuff from Aliexpress?
That is the standard lighting, but you can change the colour and brightness etc.
I could be mistaken but it doesn't look to have adaptive headlights, which for a 5 series would be a must have for me.Found this - https://www.autotrader.co.uk/car-details/202402066305704/
What's everyone's thoughts?
Seems a tad expensive and has few chavy add-ons...
Apologies if this is a stupid question, but I've not long picked up my first BMW. How do I adjust the angle of the passenger side mirror dip when going in to reverse? The angle is currently far too acute and I can barely see passed the rear wheel. In my previous Mercs you could adjust the mirror angle as normal while it was dipped and it would remember that setting. That doesn't seem to be the case here, and I can't find anything in settings to set it.
Google says that it should be possible, is not possible, and also that it's only possible via third-party coding, so not really much help there.
Sorry yeah, should have added that - M240i.
To be clear, the switch is set correctly, and the mirror dips absolutely fine. The problem is that it dips too far and I need to bring the angle up maybe 10-20 degrees.
What has beam height got to do with mirrors?Check the rod attached to the lower control arm, that's what controls the beam height.
Crazy - just did some Googling and apparently it's adjustable on Audis as well. Had no idea this was possible! Certainly isn't on BMWs without coding it in..I looked into this as I had the same issue and came to the conclusion that the dip is fixed for some odd reason. Like you I’m relatively new to mine so I could be wrong
Yeah, coding seems to be the only solution I've found too, which is a bit poor really. It makes no sense why there's an option in the system to have it adjustable, but not controlled through iDrive UI...?Crazy - just did some Googling and apparently it's adjustable on Audis as well. Had no idea this was possible! Certainly isn't on BMWs without coding it in..
i know you're on the hunt for a new car, which is my point exactly...might as well use the funds to up the budget for the new car, and leave the tranny issues to the part-ex garage/next owner
Weird how I’ve been notified for you replying to a post that wasn’t by me!The M340i has the Adaptive Suspension and the upgraded brakes as standard. There is a further optional brake upgrade available for the M340i instead.
I'm at the early stages of looking at the moment I need to search more.
I think after the master cylinder replace and bleed I won't be doing any further work on the transmission at this stage and will look for a replacement.
i'm assuming that would cost about £500? that's a decent chunk of money to spend on a car that you'll be selling in short order, no?
In the current climate, am I an idiot to consider moving from my F21 M135i to an F87 M2 Competition? They seem like incredible value at the moment.
I've always had the itch to move, more out of curiosity than anything else. I have no experience of them, so I'd be interested to see how different it actually feels compared to my current car.
