Neither..............................go have a look at Makita. Will certainly outlast anything DeWalt make and are just better built than almost anything made by Bosch.
Is it still the case that DeWalt is actually Erbauer internals in a yellow casing at a massive markup?
I bought a drill from Argos for £15.
It makes holes. Said holes work as intended. Why spend £150 on the same appliance unless you're a professional (in which case, you probably don't need advice)
Why pay more?
How round are your holes.
If you want to make another hole in a years time - how confident are you that your drill will oblige?
What if I AM a professional? In what way could the holes drilled by your bargain machine be considered 'Unprofessional'?
