- 18 Jul 2010
- Not here
You may be able to unlock L3 on the tricore. Here's a discussion, probably more around the net.
Again, try a hyper 212+ with AS5 and overclock the x3. Try unlocking the cache (if available), and extra cores. YOu may need to reduce overclock to keep it stable, or it may hold with everything unlocked.
If you still not satisfied and nothing unlocks, get a 955BE and overclock with said cooler. The HD 5850 is good enough on its own, and if it's not, reduce eye candy. That would be the cheapest route to fix your problem. That's all I can say![]()
I unlocked my tri again briefly as a test. I can confirm that mine doesn't unlock the L3 cache, which is a shame.
I also ran BC2 to see how it would fare (while keeping an eye on my temps) and found that the map loads a lot faster, I'd lag like mad when I first got into a map because it was sill loading map resources. Performance in general was a improved a bit, also.
If I got the Hyper 212, would it be recommended to use AS5? Will it provide noticeably better cooling? I only ask because I've never installed a new cooler without the thermal paste being pre-applied and if it doesn't benefit me, I'd rather avoid doing it.
In reply to your other post, my memory clock is at 1600MHz.
Best I start reading up on overclocking, also..
