- 27 Aug 2003
fozzybear said:No, why don't you tell us.
OK. Look at your fist.
Then imagine it 3.5 times bigger, and padded.
The damage is going to be a lot less if you hit someone, because the power of the punch is distributed over a wider area and the padding cushions the impact..
When you perform the same kind of punch, without a glove, you will have a higher amount of pounds per square inch in the area you have hit. Causing more damage. (to the area you've hit)
This is why boxers wear gloves, otherwise after a fight they'd be unrecognisable because of all the bruises/cuts/blood.
