I do track days a lot and personally would suggest Motul RBF600 from opieoils.co.uk
Issue with SRF is you need to get it to a reasonable temperature before you get a good bite - RBF doesn't need that. From cold mine are excellent, when warmed up they're something else!
Also would highly recommend you get something like Goodrich braided brake lines all round!
If you want to go the whole hog I couldn't recomend Carbotech XP8's more. Much better than Green/Yellow/Red Stuff etc
Have this setup on my Evo 9 and never had any issues
I think he's confusing fluid with pads or something.....
Yea i ran Halfords 5.1 in the 5 and currenly run it in the Passat and its fine, i'm sure i read its more hydroscopic than Dot 4 someplace, need to hit google and find out![]()
there is no draining and refilling. they just flush the old through with new so there is no bleeding either
Not that it necessarily means anything, but fairly obviously a liquid will expand when hot. So if SRF happens to expand a fair bit, the correct levels might be set when it's hot - certainly with F1 cars, they keep almost everything hot so they work properly off the line. So supposing SRF level is set hot due to it being performance brake fluid or whatever, it might not work so well while cold due to essentially low pressure in the braking system..
Was any of that not me talking out of my bum?![]()
So do i, £40/hour is not a viable labour rate, i would never expect a mechanic to charge that little.
Indeed, I pay £40+VAT per hour at a very decent and experienced BMW indy.thats the going rate for decent indie's here, always do a far better job than the £100+/hour places too
