Breaking into a Safe
10 Sep 2003
Midlands
I've lost my keys which had my only safe key on it. Unfortunately my passport is in the said safe and i'm going on holiday on Monday (typical).
The safe has a Q shape key hole on it. It also has a sticker with a code on the front, can I get one cut somewhere with this?
Is it one of those cheapy B&Q safes? Probably cheaper to get tactical with a crowbar/sledgehammer.
I know a builder I may have to borrow his angle grinder then, problem is the safe is screwed into the wall.
Never, ever lost my keys and this happens days before i go away grrr
If it's a cheap B&Q one, you don't need a locksmith. Get a crowbar or anglegrider and just bash your way into it.
The money you have saved on a locksmith will get you another safe to replace the one you killed.
Spare key for the future needed (i'm sure you thought of that already)
If its a cheap safe then surely a locksmith would be able to open it?
