Basically everything is going wrong with my dads computer again
and though the answer to this question won't likely help me fix the problem its still something that'd be useful to know.
If i have two HDDS in a mirrored RAID and i switch the two around on the motherboard (ie switch the sata cables form the drives) would the RAID utility be any the wiser? Would it detect the change? If drive 1 was bust and 2 ok would this fix the problem (my guess is not)?
Thanks in advance,
OSB
and though the answer to this question won't likely help me fix the problem its still something that'd be useful to know. If i have two HDDS in a mirrored RAID and i switch the two around on the motherboard (ie switch the sata cables form the drives) would the RAID utility be any the wiser? Would it detect the change? If drive 1 was bust and 2 ok would this fix the problem (my guess is not)?
Thanks in advance,
OSB
