browser issues and sluggish start up
ok uninstalled surf shark and it made no difference at all.
I maybe need to contact EE, Its odd that it works no issues with the VPN active. It doesn't work on every browser and most sites are also working fine.
Do these sites work on your phone or another computer/laptop? (Phone when going through your wifi)
Have you a spare drive? Maybe install windows on a spare drive and see if the issues persist.
I have not gone as far as that just yet with a new install.
Little update i forgot my new Motherboard came with in built WIFI , i forgot this and disabled my ethernet and installed the dongle and connect to wifi all the pages loaded no issues.
So its an ethernet side issue :(
Trouble being is speed test on Ethernet is 900Mbps and wife was less that 200Mbps.
Would rather keep them ethernet speeds for sure.
give the wife some coffee, she might go faster :p
Well, if you are sure it's ethernet. Then try changing the cable and see if that's the issue. Try changing ports on the router to see if that solves anything.
Did you try resetting the network connection/adapter?
