Brushed alu/wood über case...
If vibration is a problem - Polipods or Vibrapods (the 'cheaper' aftermarket stereo feet - AudioQuest Big Feet for the win - but you not making a Hi-Fi) pointless on carpet but if on a desk ideal.
Or google - 'rubber feet' and 'cabinet feet' for some options.
low profile ones could be mounted in for the edge so the case looks like it's floating :)
Feet are made thanks to a hole-saw and some leftover teak, will stick some chair-leg-pad thingies on.
Bits are in! However to turn the thing on I'm having to poke a USB cable end onto the motherboard jumpers :D
If anybody has a switch (any old one will do, its to be on the back) and/or a thing that will connect to the front_audio pins --> green hole.
Photos taken but need to make the perilous trek downstairs to the mac to get them off the camera so they'll be on later.
I can't stand tidying the workplace mid-job :D
Loads of room :D
If your interested:
Q6600 at 3.4ghz
2GB Crucial Ballistix
X1950 with gynormous heatsink
X-fi pro gamer
DS3r
Temps are good, idles at 33 degrees with vcore of 1.3875 (lots of droopy droopy though)
All help would be appreciated, I value your collective experience as I have none so far (except for changing RAM in a Mac Mini :p)
Jim
its a fair task mate building your own case especially if youve only changed a stick of memory
Stinka, I think this man can achieve anything if he's had the experience of changing RAM in a Mac Mini! As far as I can remember this procedure involves two putty knives, a bottle of Valium for your nerves, and a very large quantity of pot luck!
It's nice to see someone appreciates how terrifying it was :D
Any of you who think we are overreacting just go and try it for yourselves :p
