i'm on bt at the moment, they definitely aren't throttling me during the day...
It is true. The fact you're on a contention ratio means you're being traffic shaped. Somewhere along the line there will be a QoS policy that dumps your consumer grade traffic below something (or indeed everything) else and or limits it to less than wirespeed throughput. Such is tantamount to traffic shaping. But without it video and audio streaming wouldn't work. If you run a packet dissector while listening to spotify you'll probably see the IP TOS is slightly higher than that of a HTTP session.
That's because Sky connect IS BT! Sky is better but honestly you ARE still get shaped/managed/throttled. You just don't see it as much because they have so much more capacity. In about 1998 I was the first user in Stafford for NTL's (now Virgin) cable service. I was encouraged to download as much as I could. A CD's worth took 5 seconds. A gig took 10 seconds. The modem quite often reported stats that my network card in the PC couldn't cope with (100 meg PCI Intel based NIC). Then as the time came to launch the product properly I was issued with a firmware upgrade, and I was then stuck on 512 meg. Flashing the modem back to stock still stuck me at 512 meg and you could see the traffic management in use...nothings changed, you still get shapped by all suppliers, just some shape/filter more than others. Some choose to shape torrents, some shape iplayer. If they didn't everyone would complain because every type of traffic would crawl. I bet Sky shape iplayer so that their Skyplayer is better! I know I would if I was in the same boat as them. BT shape torrents so badly because they have so many more customers to keep happy over a broader spectrum, many of whom wouldn't know what a torrent was if it bit them on the bum. Changing ISP's is then your only option, but just beware that they know what you're doing and you risk the case of being prosecuted if the torrents are illegal...
Implying you had a ~1Gbps connection![]()
ISP congestion is far worse. The next place for congestion is probably the exchange if a BT product is in use. In general people should be able to max out their lines 24/7 as long as they go for a decent BT-based product (Zen Pro) or LLU (Sky Unlimited).
We have Zen FTTC and we're able to get the full 40Mb/s almost any time of the day apart from the evening when it slows to 10Mb/s due to exchange congestion.
There's no need to make folk paranoid. You get what you pay for.![]()
Hell yeah of course you do. However don't kid yourself, your traffic is still shaped mate. Exchange congestion will trigger traffic shaping to keep it all ticking along at a fair rate for everyone...bet torrents crawl during those times...everyone is shaped is some form or other!
The exchange congestion is never protocol specific, everything continues to operate but at a reduced speed.
They apparently measure your FUP by rounding up the amounts so if you download 1.7Mb it gets round to 2Mb etc etc.
I have never in the 10 years or so ive been with BT had an email or letter regarding usage.EDIT: Oh and BT's useage monitor is not that accurate at all, when they had the 100gig FUP I was carefully monitoring my combined upload/download use at the router using a flashed firmware - and I'd get the "You've used 80gig" warning around 50-60gig actual useage and the "100gig welcome to throttle hell" email around 70-80gig so they are probably right about it rounding up - also throttling would kick in on the first email despite the email stating it wouldn't happen until you exceeded the FUP (100gig).
Yup. For the trial it would certainly appear I did. I was one of less than 50 people connected via their fibre network at that time however....
Trial lasted 3 months, and then down to 512 meg
Dear Customer,
We thought you'd like to know that your broadband usage in April is now above 80GB.
In accordance with our Fair Usage Policy, and to protect the online experience of all our customers, if your monthly broadband usage goes over 100GB, we'll restrict your broadband speed at peak times (typically this is between 5pm and 12am, but these times may change depending on the demands on the network) to 1Mbps for 30 days.
Please note: your service won't be affected in any other way - we'll restrict only your speed, not the amount you can upload and download.
We'll email you again to let you know if your usage exceeds 100GB. For more information, please see our Fair Usage Policy.
4pm to midnight every single day im lucky to get 1mbit, midnight to 4pm i get the full 8mbit![]()
Like what, LLU is not an option.Get a better ISP.
