- 7 Jun 2020
I'm due to move on to BT Fibre 900 soon and will likely have to replace the Smart Hub 2 with a mesh WiFi system which I believe can be plugged straight into the ONT connecting via PPPoE. I'm after a system which is capable of providing the speeds my package is able to supply. I've been I need one with good 'backhaul'. I appreciate wired connections are the best way to go but for my circumstances this isn't feasible. I've been looking at the Asus ZenWifi, the Tri-band version or the WiFi 6 one or the Tri-band Velop AC6600. Is anyone currently using any of these units with FTTP, are you having any problems? Can anyone recommend any other mesh systems they are using with BT Full Fibre 900? Is this taking full advantage of the speed via WiFi? Thanks
