I'm also making sure any hardware I buy has cable network, ie Nvidia shield over fire TV.
WiFi isn't great really.
Ethernet adapters are available for all the Fire TV products
How do you rate the zen routers? Are they easy to set up?Fwiw I've actually been trying to squeeze the most out of my Fibre 900 over Wi-fi in the last few days, I have a couple of AX capable smartphones and no doubt this years consoles will be Wifi 6 compatible so I sold/upgraded in my existing setup for some ZenWifi AX routers. Connected one directly to the ONT and then a dedicated 5G backhaul to the other. Not bad so far and definitely shows the potential there.
Over AC ( non-Wifi 6 device )
Over AX ( Wifi 6 device )
I have a gigabit connection and I'm very interested in this. Did you get 2 ZenWifi AX routers? Trying to get as fast as possible speed to my PC without being wired to the main router. I am wondering, with the 2nd AX router acting as a node over AiMesh, if you plug something into the gigabit port on the node router what kind of speeds are you getting?Fwiw I've actually been trying to squeeze the most out of my Fibre 900 over Wi-fi in the last few days, I have a couple of AX capable smartphones and no doubt this years consoles will be Wifi 6 compatible so I sold/upgraded in my existing setup for some ZenWifi AX routers. Connected one directly to the ONT and then a dedicated 5G backhaul to the other. Not bad so far and definitely shows the potential there.
My plan is to have 1 ZenWifi AX router as the router, the other as a node next to my PC and an ethernet cable from the node to to my PC in the hope of getting something somewhat close to that 781Mbps you were getting over wifi 6. I would assume this would give somewhere near these speeds but would be great to get a confirmation.
