Is this build okay?
YOUR BASKET
1 x AMD Kaveri 7850K 12 Compute Core APU w/ Radeon R7 Graphics (4 CPU + 8 GPU Compute Cores) - Retail £124.99
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLD38G2400HC11CDC01) £67.99
1 x Intel 320 Series 120GB Internal SSD SATA 3GB/s 2.5" 7mm (SSDSA2BW120G3) £54.98
1 x Gigabyte F2A88XM-D3H AMD A88X Chipset (Socket FM2+) DDR3 Micro ATX Motherboard £53.99
1 x Deepcool GAMMAXX S40 CPU-Cooler - 120mm £19.99
1 x Zalman T2 Plus Mini-Tower USB 3.0 - Black £19.99
1 x Antec VP450P 450W '80 Plus' Continuous Power Supply £19.99
Total : £371.53 (includes shipping : £8.00).
With that said, your spec is fine and won't be too far from mine in performance, in case you have your heart set on that APU. If you want to overclock then the choice is even simpler.
Which option would be more future proof and which has more upgrade options?
Okay, how about this.
YOUR BASKET
1 x Intel Core i3-4130 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £85.99
1 x MSI Radeon R7 250 OC 1024MB GDDR5 PCI-Express Graphics Card £71.99
1 x Gigabyte Z97P-D3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £65.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £61.99
Total : £390.53 (includes shipping : £8.00).
Z97 would give you more upgrade options, yes. But ATX size won't fit in that case, so find another or choose a Micro-ATX Z97.
Get yourself faster RAM too, as Z's can handle faster than 1600MHz. 2133/2400 is the sweet spot.
And grab a Samsung 840 EVO SSD, and enable Samsung High Performance and Rapid Mode and watch it fly. It'll be £12 or so more expensive but worth it.
which heatsink would be best?
I would prefer a very quiet one.
max £20
Nope, 250 posts and above unfortunately![]()
Was it not 100 before?
