Hello all
I've been wanting to build my own 24/7 Folding rig for a while but the combination of what components to pick for some decent points and other factors (spending money that could go on a holiday!) has delayed progress. I specialise in buildings mainly gaming/general work PCs and not Folding PCs - I don't know what hardware the F@H clients favours over another but I did read through some of the posts here.
A bit uncertain
From reading the various posts on here, the consensus is to pick a 2600K for -bigadv points but how many can I expect in a day? If I only run SMP then is it wrong to assume that I won't need a good GPU at all? Or, can I expect more points from GPUs but at a huge cost?
I have a good gaming rig atm but when it comes to folding, factoring in these would help:
- Heat: I would appreciate it if this rig didn't make me feel like i'm in a sauna since it will be in the same room as my main rig - the heat will be handy nearer winter
- Costs: Nothing too exotic.
- Case: Compact case is ideal but not if it means components overheat, will spend more here for a really good case.
Tried to keep this initial post short and would appreciate suggestions from regular Folders on what has worked for them or better, thanks!
Note: I do have my work PC which is based around an old Intel QX6700 @3.3GHz air cooled, 8GB DDR2 800MHz, 4870, and a 1KW 80% efficient PSU that is too much power for that setup. For the power it uses this setup is too energy-inefficiency. I over compensated, I know
A bit uncertain
.- Costs: Nothing too exotic.
- build list to date here
