Build fail, help needed
ok quick edit:
first of all sorry for taking up your time,
so i plugged in said usb 2.0 into suggested port and only 1/3 front usb are working and 1/1 usb 3.0 ( separate source )
the os is installed but i think ive mucked it up and would like to start again, im really sorry ive been looking everywhere for answers cant seem to find any.
tapping f11 wont even load the boot menu sometimes ( am i doing it at the write time )
once again thank you so much for your patience and help, James
Hey para,
No I hadn't was watching a YouTube vid but it hasn't done it again,
I managed to re install the os however now the 2nd hard drive is not showing in my computer but it did in the installation. Could this have anything to do with the cables I used?
I got some White 6gb/s ones and used them rather than thR standard orange one- would that make a difference?
Edit: also I can't get into the bios settings I think my screen is too big?
if you right click 'Computer/My Computer' and go to manage, does it show up in the disk management section? there is a possability it isnt formated, so windows wont see it.
Yes,
I get:
Drive picture* simple- basic- ntfs- healthy( system, active, primary partition)
And
(C:) simple -basic - ntfs- healthy ( boot, page file, crash dump, primary partition)
ok, so do all rear usbs work with/without the front usb connected to motherboard?
by not being able to get into bios, you mean you press the del/esc/f2 or whatever and it wont let you in? are you using a usb keyboard?
the hard drive not being seen on startup is not a problem as such, more of an annoyance as they are being picked up, just not on the controller/type that the screen is showing you.
ok,
hard to explain the bios bit,
im using a tv 32"
i turn on computer and press Delete which should open the Bios up,
the screen / computer doesnt seem to like each other and the computer displays the msi logo really big, which means you can see the options etc. thus making the bios impossible to use.
in regards to the USB
all rear motherboard USB works perfectly fine with or without ,
when plugged in it only seems to let me use 1/3
i can get one to try tomorrow, using GFX card 6950
there are 4 usbs on the front of the case one is 3.0 the other 3 are 2.0 only one of the 3 front 2.0s work the 3.0 works fine no problems
