Build Help
29 Dec 2012
Hey there, i need some help making sure these parts will work together for my new pc build. Any help is appreciated. Also will this be able to run games like BF3 and Arma 3 on medium settings without lag ?
Motherboard - AsRock N68C-GS FX Motherboard
CPU - AMD ADX640WFGMBOX Athlon II X4 640
GPU - ASUS HD 6670 GDDR5 1GB
Ram - 4GB DDR3
Any help is greatly appreciated, thanks.
What do you mean a side grade ? Im not looking for a amazing super PC i cant afford that. I got the GPU two month ago because i couldnt afford to upgrade everything but i finally got some money now.
Get a cheap Q6600 and a second hand 7850 or something.
The GPU is pretty poor, no point getting an Athlon II and new board to accompany it.
By side grade I mean the Athlon isnt going to perform much better than a E8400. I'd grab a Q6600 like Martini sade and sell the 6670. Grab a 7850 with that money.
Agree, A Q6600 and a *b grade*/ secondhand 7850 should only set you back about £160-£190.. Selling the E8400 and 6670 will bring it within your budget. :)
