- 13 Apr 2013
- Scunthorpe
thats bang tidy, well done fella.
Thanks.
Same mate. That bend worked out looking better than expected.
I wouldn't call it easy at all. If you wanted to use fittings for all the changes of direction then that would be easy but it's super expensive and looks worse Imo. I'm glad I ordered extra tubing for making mistakes. Takes abit if planning and lots of trial and error. A bending kit helps but really not that important.
Ak ok, think i'll give it a miss then![]()
Well the end result looks excellent mate, pro bending!
how did you find doing the bending\measuring?
looks amazing but I'm always put off with water cooling as I don't like the flex stuff you can use and would much prefer the bending method
Absolutely brilliant job! You should run a masterclass![]()
Cracking looking build, that loop is fantastic.
EK blocks just look simple and stylish. It's easy to see why they are the most popular choice.
nice mod mate
Fantastic build as well you know. I've been waiting for the ATX mid tower to come out because I thought I'd struggle to fit everything in the mATX but you've done an excellent job here. Looking forward to seeing it with the coolant in and up and running. Where are you putting the drives? Also what are you doing for a fan controller? Finally, any pics of the pump and res installed? I'm incredibly nosy.
