[Build Log] The Define Project
So...
I've been hard at work, designing the blueprint for the radiator:
After printing some samples:
Then, I printed a 1:1 blueprint and attached it to the acrylic piece. After that, I started to cut with a Jigsaw:
Some stuff from today...
The "Router". This thing rolls in 23,000 rpm, compare to my Drill's humble 3000 rpm. :O
My dad is the veteran when it comes to these things so after attaching the first adapter to a new piece of acrylic he went off with the Router and cut out a new piece. This took 2 minutes compare to more than an hour with the Jigsaw!
And finally, it's ready!
Been working on the new mounting gear for the Supreme LTX (stock bits were chrome and silver):
So... a short trip to the warehouse and I bought the same conical screws only in black, same for m4 washers and m4 nuts. Then, for the springs which are harder to find in black, I painted them and also the special thumb nuts (making sure the paint doesn't reach the thread). And also, painted the back-plate with Plastidip and then trimmed it around the edges so it shows up like a course black sticker. Lastly, those are 4 screw caps which are basically conical on the inside so the screws will sit flush on the back-plate. Overall, very nice result.
Uni is starting to hog time dedicated to the project, but I really want to try and reach that end of March deadline. Also, I'm not sure if I already mentioned, but I'm now trying to get VRM & Chipset blocks for the board. There are blocks made by German brand called 'Liquid Extasy'. The major problem with that, is stock availability which will only begin in April.
Thanks! I also made this strip. It's going to cover some clearance between the acrylic adapter and the case wall. Also, it should help flexing out any noises from the mount:
Made my official trial in psu sleeving today. Failed the first attempt because I wasn't using a reducer on my heat-gun, however... 2nd attempt went pretty perfect. :)
Went back to iphone after battery died on the casual camera.
Nice one :)
Can't wait to see the final product!!!
I made a special order for z77 mpower water blocks and it's taking it's time. I hope to get some news next week or so. It's not dead, just taking long, don't worry. ;)
