Build Problem (Crashs on boot)
It's not the end of the world :) (not for 24hours anyway!).
If nothing is faulty then you can set it yourself fairly easily, just take time time to familiarise yourself with the layout and options available. It's worth learning them anyway just for your own reference :)
I see the OCUK profile but even when i click it and it said its activated/restored it still ses my CPU is at 3.50ghz
When i try and use the GPU at startup all my screen ses is Power Saving Mode and then goes black..
That just means your GFX card isn't set up or working correctly if it's not showing anything on the screen.
I assume you've tried one of the other display outputs to make sure it's not switching to one of them?
Yeah i tryed DVI and HDMI, i searched google for any hints and tips but still nothing and ive tryed a lot
Just can't help but think something is faulty if you've reset the BIOS and it's still playing up and you're not getting a display.
I havent rest the Bios because im unsure how to doit properly
Theres a button next to the motherboard DVI port that says "CLR CMOS", im taking it this is it. Do i press it when the machine is on or off
The 3.5GHz for CPU may well be because it's not clocked up yet, I'd not worry about that until you're in Windows and can use monitoring tools to check actual speed (CPU-Z etc).
Reset the BIOS using the method mentioned earlier, battery out!
Backup the profile if you can find the option in the BIOS, it is there!
Ok i reset CMOS and i get a screen!!!!! Woooooooooooooooooooo
It said
Cmos date/time not setup
f2 to run setup
f1 to continue
What do i do? Im really not sure
That's good news :)
That means the primary display was set wrong in the BIOS :D
I bought a new wirless card and it shows up on Device Manager and it can see networks but i cannot connect to my own. I got it to randomly to work but it showed a red X but still worked which was strange. After a restart its doing the same again and i cannot connect
AUXTIN is likely to be a false reading, most mobos have dummy readings here and there depending on the software being used. It's not your CPU temp though, that will be shown as CPU/CORE0,1,2,3,4 etc. If something was at 128'C then you're know about it without software having to tell you :p
What wireless card?
